Re: What are signs of weak valve springs ?
Posted by TD9 on October 06, 2003 at 08:37:04 from (156.99.90.177):
In Reply to: What are signs of weak valve springs ? posted by Pete L on October 06, 2003 at 06:09:46:
If the valves and seats were ground, the valve spring closed height will have increased. This is compensated for with a shim under the spring at the time of reassembly. Check for the shim. Signs of weak or improper closed height would be, popping and missing at high idle. If the problem is severe engough you may have misfiring at all RPM's.
If you work carefully the springs can be removed with the head on the motor. Bring them to a machine shop and have them checked for Closed height pressure. And check the closed height measurement.
Post A Followup
: Re: Re: What are signs of weak valve springs ?
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
