Re: HELP...I just got bit on a 47 A and need advic
Posted by Randy in NE on October 07, 2003 at 06:22:06 from (68.99.25.138):
In Reply to: HELP...I just got bit on a 47 A and need advice... posted by Jesse on October 06, 2003 at 14:23:11:
Just to add to a couple of the other posts. Pre-mix the anti-freeze prior to pouring into the radiator. Mix it per the manufacturer's instructions. Usually a 50-50 mixture protects to the lowest temperatures. The A has the same block as the C. My C does NOT have a water inspection port on the side of it like the bigger tractors. Removing the radiator hoses and flushing it out good with water will most likely do the trick. With the engine cold you could remove the radiator cap (carefully) and then start it up. You can check the flow of water coming from the upper radiator hose. You can either use a thermometer or your finger to see if it is starting to warm up. Just be careful that you don't burn yourself. Good luck.
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
