Farmall Tractors Discussion Board
Re: 3-Point for an H
Posted by john d on September 28, 1999 at 14:48:42 from (206.141.74.34):
In Reply to: 3-Point for an H posted by Jon with an H on September 28, 1999 at 07:36:26:
3pt makes the H a much more versatile tractor. Some types will let you end up with a fixed hitch, or drawbar instead of just a piece with holes between the lift arms. The ones with the fixed hitch are generally preferable.
You can find arrangements that use 1 cylinder, or two; if your lift is in good shape, 1 cylinder may give you all the power you need for hanging weight on the back of an H.
You hydraulic system is single acting - therefore it will extend the cylinders, or retract them, but not both. 2-way action with this system requires lots of extra plumbing.
If you hang a lot of weight on the 3pt, you may need an adjustable flow-control valve in the line to allow free lift, but restricted drop. Otherwise... things will drop in a big hurry! These are not expensive, and can be obtained from about any hydrualics supply place.
Post a Followup
: Re: Re: 3-Point for an H
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
