Re: Stuck Clutch Or?
Posted by K.B. on October 12, 2003 at 13:14:29 from (209.163.30.73):
In Reply to: Stuck Clutch Or? posted by Slowpoke on October 12, 2003 at 12:41:45:
Did you have the clutch pedal depressed when you dragged it in 4th? That would break a stuck clutch disk loose. Other than a stuck disk, there isn't too much else that would cause the problem of not being able to put it in gear with the engine running, if it works fine now. Ajust clutch pedal free travel and remove the inspection cover from the bottom of the clutch housing, just to see if everything looks normal, and you should be ready to go. Have fun digging out the oil filter o-ring, I've been there too. Getting a brand new one in there sure makes a difference. Good luck with the 240, they're great. Is yours a Row-Crop or a Utility?
Post A Followup
: Re: Re: Stuck Clutch Or?
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
