Charging is this right?
Posted by chad from michigan on March 30, 2009 at 18:51:31 from (67.142.164.24):
Hey I finaly got the Super A charging. I put a different generator on it and things started working. Anyway when the LHDB switch is on low it charges just over "0" I mean just over but if I switch it to high charge the amp meter shows about 12 volts.
Is this right?
Now we have an 8 volt battery on it and I ran the trator with the gen wire un-hooked off the cutout and checked the voltage at the battery while running it showed 8.40 volts then I ran it on high and low charge and it only went up to 8.5 volts on the battery with everything hooked up.
does it sound right?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
