Re: Gerator on Super A causing me Grief.
Posted by steve on October 23, 2003 at 19:31:05 from (204.246.222.80):
In Reply to: Gerator on Super A causing me Grief. posted by Brian on October 22, 2003 at 19:51:13:
the light switch is used to ground the "F" terminal of the generator. bypass the switch by running a wire from "F" to ground. --start tractor and see how that works. if the amp meter does not show a few amps charge and volt meter show slight charge, then... --- Take the "G" terminal and "B" terminal wires on the regulator and connect together. this will bypass regulator and run generator "A" to the ampmeter, then thru ampmeter to battery. (other side of battery is gound)... --start tractor and note charge, the regulator is out of the system and the generator should go to "full charge" which will only be 10 amps. you can run this way for several minutes for a test. --you have now narrowed down if you have a good switch, if the regulator is working, and if the generator is putting out power. --by the way, if you take the wires off the generator and ground the "F". then startup the tractor and measure voltage across the A and F terminals (A connected to nothing) you will get probably 10-15 volts output. it is the battery and regulator that adjust it down to 6 volts.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
