Re: Electronic Ignition
Posted by Doug in OR on October 28, 2003 at 07:09:11 from (12.225.61.140):
In Reply to: Electronic Ignition posted by John in NE on October 28, 2003 at 06:27:56:
I use the Pertronix electronic ignition on an M. It works just fine. I did convert to 12 volts, negative ground, though. You might want to check a few other things first. First of all, are the points well-grounded? Rust and corrosion where the points are screwed into the distributor can cause resistance - resulting in low coil voltage. Are all electrical connections nice and tight and clean? Check everything in the ignition circuit. Is the coil good? A bad coil can fool you. Put a voltmeter on the ignition coil too - with the points closed. You should have nearly 6 volts on the input side of the coil, and nearly no voltage (under .5 volts) on the side going to the points. If you have a bad coil or poor ignition connections, electronic ignition won't help you. I use electronic ignition because it is more maintenance-free. You don't want to use it to mask another problem.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
