Re: Re: Why won't these sleeves budge?!!
Posted by Brad L on October 30, 2003 at 18:38:11 from (67.40.167.101):
In Reply to: Re: Why won't these sleeves budge?!! posted by Jonathan Mirgon on October 30, 2003 at 18:01:31:
If the sleeves have been damaged to the point of what does it matter I have an idea. Have never tried it but I have heard you came run a bead ariund the inside of a stuck bearing race and when it cools the race just about falls out. MAYBE? that would work with a stuck sleeve also. You also could maybe use the dry ice inside the sleeve after you welded your bead to contract the sleeve fast. the shock may crack it loose. Have ot ever tried this but it might work.. Just a thought. Brad
Post A Followup
: Re: Re: Re: Why won't these sleeves budge?!!
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
