Re: M still running rough
Posted by Hermit on November 07, 2003 at 19:37:42 from (69.21.48.50):
In Reply to: M still running rough posted by Ty on November 06, 2003 at 19:32:54:
I've measured the dwell at 63.0 degrees - 70 percent for a .020 points setting. I'd be wary of using a digital voltmeter to measure pulsating DC like an ignition system. It takes a digital meter time to stabilize on a reading. An analog meter might work better. Have you checked for vacuum leaks around the carburator and intake manifold? Also, I'd set the timing with a timing light at idle rpm. Then watch for timing increase as rpm increases.
Post A Followup
: Re: Re: M still running rough
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
