Farmall Tractors Discussion Board
Re: IH-560 D with 403(?) gas engine
Posted by SDman on October 01, 1999 at 22:25:03 from (63.65.237.137):
In Reply to: IH-560 D with 403(?) gas engine posted by Mr Gadget on September 30, 1999 at 13:58:45:
Gadget, there are probably a half dozen tractors (560s, 656s, 706s) around here that have combine engines instaled in them over the years (an old IH mechanic who is retired has done most of them). If I remember right, you must use the front cover off of the tractor engine(combine engines don't have the ears to mount the front cover into the frame rails), the carburetor off of a tractor(combine carb air inlet is towards the back of the engine, tractors are to the front), I think the combine engine also had a hydraulic pump mounted on the engine that must be removed. Most engines sought after from the combines were 403s (263 cu. in. gas), 503s & 715s(both had 301 cu. in. gas engines). The best way to tell if its a combine engine? Pull the head & much to your disappointment, you will find that a combine engine never had sleeves so when OH time comes around, you will have to bore the block.
Post a Followup
: Re: Re: IH-560 D with 403(?) gas engine
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
