Re: SMTA hangs in gear. Is it TA RELATED?
Posted by Red Rider on November 09, 2003 at 19:22:06 from (66.248.97.207):
In Reply to: SMTA hangs in gear. Is it TA RELATED? posted by RB on November 09, 2003 at 15:15:40:
RB, the TA system uses planatery gear sets to obtain the low range. Even if your TA is adjusted correctly it will not come out of gear for the following reason. Planatery gear set will not rotate backwards. If your tractor is in direct drive (TA forward) and in a forward gear on a slight up hill angle with your clutch in, the tractor will have rear ward pressure on the planatery gear set and will not come out of gear very easy. This also applies if say you were in reverse and backing up a slight incline. It doesn't take much pressure against those planatery gears to cause a slight bind. When you pull the ta lever back and it comes out of gear easy it is because you are releasing the TA clutch. With my tractors I can tell if the tractor is going to roll back a little when I stop so I just clutch and shift out of gear just before for momentom stops.
Post A Followup
: Re: Re: SMTA hangs in gear. Is it TA RELATED?
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
