Re: coil wire
Posted by Bob on November 16, 2003 at 11:07:26 from (66.163.134.177):
In Reply to: coil wire posted by Brooks on November 16, 2003 at 10:36:23:
Negative ground tractor... Power wire from ignition switch to (+) side of coil. Wire from (-) side of coil to breaker points/condensor.
Positive ground tractor... reverse the above
connections.
Does that answer your question about where the wire goes... I'm not sure I understood what you were asking?
And, yes, it is true you do not need a ballast resistor IF YOU HAVE A 12 VOLT COIL SPECIFICALLY LABELLED "NO EXTERNAL RESISTOR REQUIRED".
Post A Followup
: Re: Re: coil wire
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
