Re: Re: Which is best when changing to 12v?
Posted by jdemaris on November 21, 2003 at 05:48:53 from (209.23.28.63):
In Reply to: Re: Which is best when changing to 12v? posted by 49 Cubber! on November 20, 2003 at 17:38:13:
If your mention of a "resistor to the starter" is in response to my posting, you seem to have mis-read it. I mentioned a resistor "bypass", which actually has nothing to do with the starter. A tractor with a 12 volt battery and a 12 volt starter will generally drop to a system voltage of somewhere around 9 volts when cranking. That's why, when being tested, a 12 volt battery is load tested at 9 volts. So . . . when a tractor is being cranked, the coil will also be getting around 9 volts if its getting full system voltage. If it's hooked to a resistor, it might be getting only 4-8 volts - which is still enough to start and run in most conditions, but sometimes won't in cold weather, with fouled plugs, bad wires, wet cap, etc. That's the reason why most ignition systems have some sort of way of bypassing the resistor when the engine is cranking. Ford had the bypass built into their relays, Delco had it built into their 12 volt solenoids. Some companies built it into their starter switches. It's a simple thing to do, and can be added to any tractor with $10 in parts. There are also some coils built with internal resistors that are heat sensitive, and kind of accomplish a sort of "bypass." When cold, they pass full current, but once running for awhile, they heat up, and resistance increases, voltage drops, and thus the life of the ignition point life is enhanced. Another way to increase voltage during cranking is to use a bigger battery. The bigger the battery, the less voltage drop during cranking. I don't want to make an academic study out of this and get over-technical. My point is, if someone wants to take to time to update their tractor, why not take an extra ten minutes and do it right?
Home
| Forums
Today's Featured Article -
Fasteners: The Nuts and Bolts of Nuts and Bolts - by Curtis Von Fange. The nuts and bolts of nuts and bolts is an interesting and essential piece of knowledge that applies to our older tractors. An improperly torqued capscrew on an engine head or a shear bolt that is too hard on the driving shaft of a bushog can create havoc and make an expensive and uncalled for repair. Let’s examine the purpose and design of these fasteners in order to ensure their proper use. Fasteners are probably one of the aspects of mechanics that is given the least amount of thought.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
