Re: FARMALL H RUN'S ROUGH
Posted by Farmall Daddy on November 26, 2003 at 16:15:51 from (209.163.43.152):
In Reply to: FARMALL H RUN'S ROUGH posted by JIM GILLER on November 25, 2003 at 19:38:11:
I had the same problem with my '49 Farmall M. I ended up having to re-do the entire fuel system, as in a new line, sediment bowl, screens, and a carb rebuild. To do all that, it isn't that hard. What I would do first is shut the fuel off, take the sediment glass bowl off, and turn the fuel on to see if you have dirt at the bottom of the tank which would restrict fuel flow, or to see if your tubes inside the sediment bowl housing is full of rust, dirt, etc. If fuel is good there, put the bowl back on, but make sure to fill the glass bowl up first so an air pocket won't stop fuel flow. Take the fuel line off the carb, and turn the fuel on. If it doesn't run out there at a good pace, then it is not the carb. If is runs out good there, check to see if your float is rubbing on the top side of the carb. That would indicate that the float is stuck at the top of the carb, and not releasing the needle valve. But, I warn you, do not bend the float, or you will have bigger problems. I had to remove the carb off my M 23 times before I figured out that I had a bent float. Bent floates will make you not get enough fuel, or worse yet, make your carb overflow. Best of luck with it!!
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
