Re: Farmall H timing with a distributor
Posted by Gary-Miss on December 14, 2003 at 15:44:36 from (152.163.252.227):
In Reply to: Farmall H timing with a distributor posted by Mark on December 14, 2003 at 15:17:33:
Same difference as a magneto. The plugs can't tell the difference. The only thing is, the mag has an impulse that you have to turn past, then, back up to. Get the timing mark you want, turn the ignition switch on, rotate the distributor in the SAME direction as the distributor shaft turns, then, real slowly rotate the distributor AGAINST the direction of rotation until itsparks. Lock it down. You will probably have to do this several times before you catch it at the exact moment it sparks (the points open)
Post A Followup
: Re: Re: Farmall H timing with a distributor
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
