Farmall Tractors Discussion Board
Re: What to use to protect the electrical connections?
Posted by HR on October 06, 1999 at 13:04:24 from (207.115.63.23):
In Reply to: What to use to protect the electrical connections? posted by Marvin on October 06, 1999 at 10:34:11:
Marvin: You asking the $64 question. What to do about the constant problem of corrosion in electrical circuits since Mr Edison. Any two metals that are different with electrical current will react to produce corrosion.. Copper wire & steel, tin etc.. Keeping things dry and as clean as possible go a long ways..Try Radio Shack for some of the latest spray cans of cleaner\sealer.. Maybe even auto parts stores.. Baking soda & water will help clean parts from battery acid.. Sometimes I smear a lite coat of grease over the ends of cables before attaching.. Collects dirt but it helps seal out oxygen.. Corrosion is probably half the reason many hide needed repairs and go to 12volt systems. Get as clean as possible and keep dry and spray on a sealer.. Also another good reason to keep it in a barn\garage.. Good luck getting it all cleaned up.. Just thought that sometimes cables that are damaged midway have hidden corrosion which reduces its ability to carry full current load.. sorta a fake out since its looks good with a coat of paint on it.. Well worth doing this repair in the long run.. harvey
Post a Followup
: Re: Re: What to use to protect the electrical connections?
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
