Re: Super M carburetor valve
Posted by rebuilder on December 17, 2003 at 13:06:18 from (216.241.135.193):
In Reply to: Super M carburetor valve posted by Tim Malin on December 17, 2003 at 12:09:21:
Tim: I rebuild a lot of carburetors and this particular problem(gas leaking out of carb.) is my most frequent. I have no one answer as there are several things causing the leak 1) dirt in the needle valve causing to stick open. make sure fuel filter & inlet are squeaky clean. 2) Float dragging against carb. bowl. Take off carb. & Twist it in you hands in various positions. You should be able to hear or feel float moving on it's axle. 3) Float filled with fluid from leak. take off & shake float, even a very slight amount of fluid in float can keep it from working properly. 4) various other problems. I have actually had a beatiful looking carb inside & out leak gas & the only way I found the problem; I filled the carb. bowl with gas while I had it apart and found a tiny crack internally in the housing totally hidden from the naked eye. 5) usually the first thing I have a customer do though is to make sure needle valve is clean then try bending the float down a small amount. I have a gut feeling that the newer valves are somehow different than OEM causing these leaks either from imprecise manufacturing or poor materials. Nothing I can prove though. But most times bending the float down will cure the problem. Good Luck!
Home
| Forums
Today's Featured Article -
Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
