Re: M engine locked up\starter bad?
Posted by The Red on December 21, 2003 at 14:18:11 from (12.74.55.223):
In Reply to: M engine locked up\starter bad? posted by Mike (IL) on December 21, 2003 at 12:05:58:
As has been mentioned, the ring gears on the old Ms get worn and the starter bendix gear gets hung up on a tooth. Loosen the starter and see if you can turn the engine via the fan blades. Tighten the starter back in and you should be OK. My neighbor Ernie has an old M that hangs up once out of every 20 starts. We keep a 7/8" box wrench in the tool box on the tractor. Depending on which year you have, you will have either a 2 bolt starter to the frame or a 3 bolt with a smaller bolt head in the later Ms.
Post A Followup
: Re: Re: M engine locked up\starter bad?
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
