Re: possible electrical problems?
Posted by Hugh MacKay on December 22, 2003 at 19:04:02 from (209.226.247.153):
In Reply to: possible electrical problems? posted by Diana on December 22, 2003 at 16:05:41:
Diana: You've lost me on the sequence of events. As I understand it you went to tractor had glow plugs on and this heat and smoking occured before you tried the starter, am I right or wrong? Or was the solinoid stuck from last time you used tractor? I'm just trying to rule out the possibility of the problem being in your glow plugs. Back a few months ago I think you told me those glow plugs were activated by a toggle switch rather than a push button. That 350 is a bit different breed than other IH diesels with glow plugs, being a Continental diesel. Most diesels use a push button for glow plugs. I'm just wondering if you also don't have a wiring nightmare. Did you ever check wiring out with diagram from manual? I'm not suggesting the others are wrong, on the starter assumption, just check all possibilities.
Post A Followup
: Re: Re: possible electrical problems?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
