Re: Re: So how safe are we?
Posted by Robert on December 30, 2003 at 20:10:10 from (208.23.178.138):
In Reply to: Re: So how safe are we? posted by RandyN in MO on December 30, 2003 at 19:00:56:
Actually, Randy, while this concept seems very simple, it is even simpler than that. While the phrase 'Center of Gravity' is probably well understood, it is not the correct phrase here. The center of gravity of the tractor is not an issue. If you imagine a tractor with a variable hitch height, imagine a tractor with a hitch height (pick a number, say 20 feet) that high in the air. Wouldn`t take much pull toward the rear to lift the front of the tractor off the ground. Start lowering the hitch height, and the result is that more pull would be needed to lift the front end. The effect continues until the hitch point reaches the ground. Lowering the hitch height below the rear axle, there is nothing magical that happens. Lowering the hitch height to ground level is the ultimate loss of lifting effect. Raising the hitch height anything above ground level causes a decrease in weight on the front wheels as pulling force is applied. If you could actually lower the hitch point below the surface of the ground, pulling force would actually put more weight on the front wheels, transferring weight from the rear wheels. It's just that lowering the hitch height as much as possible will usually cause the tractor to lose traction before enough weight is taken off the front wheels to cause them to lift off the ground. I had a gooseneck grain trailer that one time I had 300 bushell of corn on and attempted to pull it (Slightly) uphill in soft ground behind a Deere 4230. The hitch was a little higher than when the trailer was hitched to the fifth wheel in the pickup. I had ten suitcase weights on the front of the 4230 and could not pull the trailer. All the pull and weight of the trailer on the hitch was above the level of the 3 point arms in the raised position. Any pulling force I applied would lift the front of the tractor before the trailer moved. Factory made hitch for the trailer and very dangerous. Good only for moving the trailer when empty.
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
