Farmall Tractors Discussion Board
Re: Farmall M Govenor Adj
Posted by Bob M on October 11, 1999 at 08:11:38 from (192.232.120.194):
In Reply to: Farmall M Govenor Adj posted by Greg Lasher on October 10, 1999 at 20:16:17:
Greg -
Before you do anything else this: Loosen the two screws that hold the cross tube to the governor riser. Pull up on the cross tube then hold it there while retightening both screws. Now try your engine and see it the problem has disappeared.
If the above doesn't work you need to adjust (shorten) the rod between the governor arm and the cross tube shaft. The rod is threaded on the upper end (it's probably all gunked up so you cannot see the adusting threads). Need to remove the small cotter pin in the crank block at the top of the governor rod, disengage it from the cross tube shaft and then turn the block clockwise a turn or two. Put it back together and give it a try.
Good luck!
Post a Followup
: Re: Re: Farmall M Govenor Adj
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
