Re: where to check trans. oil on Super C
Posted by Randy in NE on January 14, 2004 at 06:13:08 from (216.58.237.20):
In Reply to: where to check trans. oil on Super C posted by Larry B. on January 14, 2004 at 06:01:23:
It should be the same as on a C. It is on the back of the rearend just below the belt pulley. There is a square headed plug. The level should be up to that level, or reasonably close. You can add oil there or through the fill plug in the operators platform next to the clutch peddle. It has a recessed 1/2" (might be 3/8") head in it. Your 1/2" drive rachet should fit right in it. The transmission/rearend holds just under 5 gallons. Depends on if you drain the oil out of the pto housing. There is an oil slinger in the rearend that supplies oil to the pto. Most but not all of the oil will drain back into the rearend. The drain plug is located on the bottom of the housing and you need to remove the drawbar to get at it.
Post A Followup
: Re: Re: where to check trans. oil on Super C
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
