Adding a water pump to a Super A?
Posted by SAm in NS on January 17, 2004 at 15:12:54 from (24.138.19.172):
I was using my Super A today for plowing snow and as it warmed up I started opening the throttle and applying more load. After maybe half an hours running I was a bit over half throttle when I noticed considerable quantities of steam coming from under the rad cap (it's a little loose). Taking the load off and running it at idle solved the problem enough to finish another 5 minutes or so of plowing but there was still a small amount escaping. I have had the radiator recored recently and the new core has much smaller tubes (although twice as many). It was about 0 degrees celsius here today so I'm thinking I ought to add a water pump. If I do this, where can I get the parts from in Canada? Also I'll need a thermostat (do I also need a new upper water hose connection to mount the thermostat in?), pump, and belt. Should I also install a temp. gauge at the same time? Is there anything else I need to think about or know to do this? Thanks, SAm in NS
Post A Followup
: Re: Adding a water pump to a Super A?
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
