Re: Re: Re: cub cadet paint
Posted by lee on January 17, 2004 at 19:10:40 from (24.24.92.235):
In Reply to: Re: Re: cub cadet paint posted by RICK on January 17, 2004 at 14:25:01:
I use a viscosity cup to measure the viscosity for thinning for my spray gun. The viscosity cup is a cheap plastic dipper like cup you can get at an automotive paint store The cup has a hole in the bottom. You dip it in the paint, pull it out and time how long it takes to empty the cup. 18 to 21 or more seconds should be in the ball park. What works best will depend on your equipment
setup and conditions. Adjust the viscosity as required and test spray to find what works best. You can just count it down or use a watch with second hand. I do it this way because it makes for very consistent viscosity every time. You don't have to measure the paint or thinner. You can thin up just the amount you think you need. Put some paint in a clean cup and add a little thinner. Stir it good and test the viscosity. Add thinner as required to get the viscosity where you want it. I would use VM&P Naptha as thinner for alkyd enamel. If you don't want to use this method I think you just have to try the recommendation on the can of paint you have. Case IH Iron/Guard is up to 8:1 (paint to thinner) reduction. Other paints may say they can be thinned 15 to 20%. I like the viscosity cup so I don't have to measure and thin by percentages or ratios. Always mix in a separate cup and then strain your paint into the clean paint cup you use with your gun. Paper strainers are available at the auto paint store.
Post A Followup
: Re: Re: Re: Re: cub cadet paint
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
