Re: stuck in gear
Posted by Farmer Bob on January 18, 2004 at 11:54:25 from (64.113.13.192):
In Reply to: stuck in gear posted by Peter Bernegger on January 18, 2004 at 11:10:39:
Remove the soft plug from one side of the casting at the bottom of the gear shift. There is a pin that goes through the shifter that has to be punched out of the casting so you can lift the shifter up out of the casting. Once it is out, use a light to look down into hole and you'll see the shifting rails. Using a long heavy duty screw driver align all the rails so the large notch in each rail is lined up even and in the center of the hole. Now look at the very bottom of the gear shift shaft. You'll see how worn and rounded off it is. You can build it back up with weld and then dress it up on the grinder to prevent this from happening again. If you are unsure of how much add to it or grind off, take it to your Case/NH dealer shop and have them correct it. Put the shifter back into the slot, push the pin back in and then install the soft plugs on both sides of the casting to hold the pin in.
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
