Re: Super H Brake questions
Posted by SGT K on January 18, 2004 at 19:11:26 from (65.120.161.38):
In Reply to: Super H Brake questions posted by PeteNY on January 18, 2004 at 10:36:25:
Pete, I don't know about the avaialability of the brake shafts, but if they are like an H they come out with the bull pinion assembly. Don't be tempted to pull the assembly without moving the bull gears. If you do you will break the flange that holds the inner bearing. I just went through this on my regular H. Aces and rebuilder gave me a good tip, remove the PTO and you can then remove the cap screw and large washer that hold the axle to the bull gear. Then take the wheel off, then the axle cap that has four 3/8 bolts. You should be able to slide the axle out and free the bull gear. Pull the bull gear to the rear and swing the rear of it toward the center of the rear end. This will give you enough clearance to pull your bull pinion assembly from the side of the case. I did both sides of mine. On one side the axle did not cooperate, so I removed it with the entire axle housing. Its not to bad of a job, it sounds worse than it is. Just be careful and be sure your bull gear is pulled back and not catching your inner bearing flange as you pull the bull pinion assembly, and you really need to have two people to slide the axle back into the bull gear. Again, I'm not the sharpest guy working on a Farmall, but I got this tip here and it worked great. You can read the tips the guys gave me a couple of days ago under END PLAY and END PLAY FOUND. What I described is for a regular H, but I believe it would be the same for a Super.
Home
| Forums
Today's Featured Article -
A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
