Odd Resistor Electrical behaviour
Posted by Dave Craft on January 19, 2004 at 19:11:26 from (24.27.10.239):
I've been tracing an electrical problem in my farmall 404 and finally arrived at the resistor as my problem. The tractor would attempt to start but when I let off the starter button it would not run. I subsequently determined that the push button starter is wired in such a way that it bypasses the resistor (hence the "almost" running). Once you let off the starter switch the electrical supply to the coil flows thru the other path which includes the resistor. My problem: Once I place a wire between the poles of the resistor (essentially bypassing it) the tractor will run. At that point I thought....bad resistor! However I took it off and checked it with a voltmeter. It shows 0 ohms resistance between the poles (like a straight wire!). In addition when I test it in series with a 12 volt battery, the voltmeter shows 12 volts (essentially it is performing no resistance...again just like a straight wire). I would have expected the volts to drop across the resistor to something like 6 or 7 volts. I think normal running of the tractor requires something less than the full 12 volts, hence the need for the resistor. So if it performs like a straight wire in tests it should allow the tractor to run...but it doesn't. Note that I think if I did straight wire it...or just use this "odd" resistor...I'd eventually burn the points, as 12 volts is too much. The IH mechanic claimed the resistor had to be put on in a certain direction. That was wrong because A) the posts would have been labelled as such and B) I checked it in series with the battery with the current flowing to either post and get the same result. Ideas? Is this resistor kaput? Could I have done something to cause it to die? I have noticed it being warm to the touch.
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
