Re: Re: hard starting Super A
Posted by Bob M on January 22, 2004 at 07:29:55 from (165.170.128.66):
In Reply to: Re: hard starting Super A posted by john koritansky on January 22, 2004 at 06:02:24:
Your description leads me to believe you've got a weak spark problem - probably caused by a weak or mismatched (12 volt) coil. Suspect what's happening is the coil is providing an adequate spark on full 6 volts, but fails to provide a sufficient spark on the 4 volts or so it gets while cranking. This is why the engine sometimes fires the instant you release the starter switch, and why it fires up easily when hand cranked. It's unlikely the starter is drawing excessive current. If it was the engine would crank very slowly or not at all. Also the starter would overheat (and probably begin smoke) after only a few seconds of cranking. A couple quick tests: 1 - If you have a DC voltmeter place it across the battery terminals and observe it while cranking. If it reads no less than about 4 volts while cranking the starter is not drawing excessive current. 2 - Pull the center cable from the distributor cap and attach it to a good spark plug. Lay the plug on grounded metal. Now turn on the ignition and crank the engine with the starter while observing the spark at the plug. If you see a lazy yellow spark, intermittent spark or no spark at all you've got an ignition problem. (You should see a hot, blue spark each ½ revolution.). Now have an assistant hand crank the engine while observing the spark plug. Chances are you'll now get the hot, blue spark when hand cranking. Assuming it is an ignition problem the first thing I'd do is replace the coil with a new 6 volt coil. And while you're doing that spend a few $ for new points and condenser. Hope this helps...
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
