Re: 300 Runs Riiiich, carb parts
Posted by Ray in Pa. on January 25, 2004 at 21:00:28 from (205.138.20.116):
In Reply to: 300 Runs Riiiich, carb parts posted by Bill in Orono, MN on January 25, 2004 at 18:48:27:
Bill, I think that 5 turns out on the main jet adjusting screw is too rich. After 10 years of experimenting with adjustments, I have found that on my Farmall 300, my tractor runs best with the main adjusting screw set about 2 to 2 1/2 turns out. I have discovered that anything more than 3 turns out will cause spark plug fouling and poor gas milage with no increase of power. My tractor also runs best with the idle jet adjusting screw set at 1 turn out. Setting the idle jet adjusting screw more than 1 turn out will bring on spark plug fouling also, and increase fuel consumption. Setting the idle jet adjustment less than 3/4 turn out, will cause the tractor to be harder starting due too lean adjustment, run poorly, cause hesitation and lack of power. The idle jet adjustment is very sensitive with as little as 1/4 turn when its near its best running setting.
Thanks Ray in Pa.
Post A Followup
: Re: Re: 300 Runs Riiiich, carb parts
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
