Farmall Tractors Discussion Board
Re: Re: Re: Re: HELP! Battery running dead...
Posted by Pete in PA on October 13, 1999 at 19:23:31 from (208.157.96.50):
In Reply to: Re: Re: Re: HELP! Battery running dead... posted by ltf in nc on October 12, 1999 at 20:15:34:
ok, the voltage regulator (this is not going to be too helpful a description - it has no identifying markings on it) is a black cube located to the rear of the generator with one wire coming into the front, and three coming out of the back...difficult to trace where the wires lead...
I did switch positive-to-ground, and after recharging (the dead or dying) battery i was able to get the lights to work, and now when I pull the starter ring, the voltmeter needle dips into the negative side....which i assume is good, yes? before when i tried to start it the needle swung about 5 volts into the positive, which now that i think about it makes little sense. Is this about accurate, or am i completely off base?
Also, thanks for the tip re the magneto / distributor...it has a distributor, i just didn't know if IH decided to hide a backup magneto somewhere...
thanks for all your help (and patience...)
Pete in PA
Post a Followup
: Re: Re: Re: Re: Re: HELP! Battery running dead...
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
