Re: Leaking oil around brakes on an H
Posted by SGT K on February 07, 2004 at 19:55:50 from (216.125.213.243):
In Reply to: Leaking oil around brakes on an H posted by Andy in Ohio on February 07, 2004 at 17:16:27:
Andy, I just went through this, and I got a lot of good advice here. I also had a lot of end play in my pinion shafts. My problem was one of my bearings was loose on the shaft, and my bearings were also loose in the housing. I fixed mine by pulling the PTO assembly, taking off the cap screw and large washer from the axle, removing the four bolts that hold the axle seal and pulling the axles. After pulling the axles I was able to pull the bull gears back and toward the center of the rear end. This allows enough room to pull the bull pinion assemblies without it catching on the bull gear. One of my axles did not want to pull out so I removed the axle housing with it. My bearings seemed good, so I center-punched the housing and shaft, then lock-tighted them when I put the assembly back together. I also double sealed the shafts and packed grease between the seals, just because it seemed like the thing to do. You can read this advice first-hand from the people who gave it to me if you do an archive search under "bull pinion end play" or "end play solved". I hope I explained this well enough, if you have any more questions just ask, someone here is always able to help. Good luck. SGT K
Home
| Forums
Today's Featured Article -
A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
