Farmall Tractors Discussion Board
Re: Can an IH 6v generator be converted to output 12v?
Posted by Marvin on October 15, 1999 at 17:44:19 from (134.134.248.18):
In Reply to: Can an IH 6v generator be converted to output 12v? posted by JR on October 15, 1999 at 09:25:08:
I agree with Ludwig. Find out why you have problems with the 6 volt system. Changing the battery out to a 12 volt system only masks the problems that will come back and bite you later with the 12 volt system.
When you switch to 12 volts you can add a resistor in series with the output of generator to reduce the current being sent to the battery. This is how the generator works for the cub and A 6 volts systems. On the dash of these tractors there is a switch that allows you to select LOW or HIGH charge. The LOW selection just adds in a resistor to teh charging circuit, whereas the HIGH setting shorts out the resistor. You could do the same or get the shop that makes changes to you generator to add a 12 v regulator. I would go the regulator route, that way you do not need to monitor the amp gauge and remember to change the switch from High to Low or low to high.
Just my two cents.
Post a Followup
: Re: Re: Can an IH 6v generator be converted to output 12v?
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
