Farmall Tractors Discussion Board
Re: Re: M electrical
Posted by ltf in nc on October 16, 1999 at 07:20:04 from (206.228.213.186):
In Reply to: Re: M electrical posted by RED Blooded on October 16, 1999 at 04:45:05:
Obviously the system is not charging. You need to determine if the problem is in the regulator or in the generator. Do the following...check the water in the battery...check for obvious wiring damage.....make sure fan belt is tight ....run engine at medium speed and jumper from the regulator base to a good ground, if it starts working the ground on the regulator is not good...jumper with the engine running medium speed from the regulator terminal marked ARM/GEN to the regulator terminal marked BAT, if charging increases replace regulator.....connect a wire from FLD terminal on regulator to a good ground and run engine at medium speed, if charging increases replace regulator, if charging does not increase remove generator and take it to a rebuilder for further checking. At the test points where indicated to replace the regulator try to salvage the old one by removing the cover and filing the oxidation on the points.
Post a Followup
: Re: Re: Re: M electrical
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
