Farmall Tractors Discussion Board
Hydraulic Oil and ?
Posted by MrGadget on October 16, 1999 at 12:00:30 from (207.91.28.133):
I was going to change the oil in the trans/dif on the 560 today. Drained about a qt of water outa the lower rear, and a cup or so outa the front before I got to pure oil. Since it is apparently seperating, must not be Hy-Tran, cuz that will absorb water, right?
I can still stick my finger in the sight plug hole and find oil very close to full. So I'm not too anxious to change it if I don't have to. Was going to add some oil with what I had before spending $80 on Hy-Tran. Assuming that's what I actually need(?).
I have a 5 gal bucket of Univis N46 High VI hyd oil. Meets Denison HF-0, HF-2; Milcron P-70; Vickers I-286-S, M-2950-S. It's almost clear. Is this anything close to what I should put in there to top it off? If not, what CAN I use this stuff for? Price was right, I got at a farm sale, unbroken seal for $1.
Also the guy at the parts counter said that my tran/diff and hydraulics are all one big reservoir. I'm not so sure about that, becasue there appears to be a second smaller case in between the engine block and the transaxle case. This smaller case includes the clutch bell housing and has a rectangular plate under it, with a drain plug that requires a 1/4" square allen type wrench to remove it (which I don't have). WHat is this casting, and is it connected to and sharing the same oil as the trans/diff? If seperate, what do I need to do to service it?
The manual is on order, but I'm too antsy to wait. I want to use my tractor!
Post a Followup
: Re: Hydraulic Oil and ?
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
