Re: Tighten up steering on Super A
Posted by Hugh MacKay on February 28, 2004 at 15:59:54 from (64.228.11.105):
In Reply to: Tighten up steering on Super A posted by J Risher on February 28, 2004 at 14:20:44:
J Risher: Inside your steering box there is a worm on the shaft coming from steering wheel. The other shaft going down through bottom of box with steering control arm attached has half cog inside driven by the worm on other shaft, That half cog is keyed to shaft with woodruff key. You can get lot of looseness right in that key. That one is the cheap and easy fix. You just have to remove front axle and drop bottom from steering box. I have run across a few of these with key way damage. I use a larger key and grind it to make a tight fit. I did fix one by welding key in shaft and grinding, but leaving it tight enough cog had to be put on with a press. It is really your call when you see how bad the key and keyways are.
Another item that can cause looseness is a worn worm and cog. You can expect to pay dearly for them. I was quoted over $400. about 10 years ago. I decided that tractor could become my off road tractor.
Post A Followup
: Re: Re: Tighten up steering on Super A
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
