Re: farmall Tractor rear axel problem
Posted by lee on February 29, 2004 at 09:10:24 from (24.24.92.235):
In Reply to: farmall Tractor rear axel problem posted by Jon on February 29, 2004 at 07:08:12:
I've done these. They can be stubborn. Sounds like you have the axel housing off the tractor?
If the bull gear is contacting the housing it has moved some! You need to persuade it harder!
Do you have it blocked up solid so you can get a good bump on it with your persuader. How big is your persuader? I used a 6 lb maul and drift. It is s stuck now on the inner bearing for most part or on dirt and grease in the bore of the outer I gather. The shaft must be bumped thru the innner race of the inner bearing. The bull gear is splined to the axel shaft and just slides on so axel should pass thru. MAKE SURE YOUR BOLT IS NOT CONTACTING THE INNER RACE OF THE INNNER BEARING. You may need a drift on the shaft slightly under size of inner race. If you have a torch you can heat the nose of the casting some near the hub and/or the inner bearing if possible if you plan to replace. If you cannot get it you will need to take it and have it pressed out. Replacement of bearings may be necessary.
Post A Followup
: Re: Re: farmall Tractor rear axel problem
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
