Re: Age of McCormick-Deering 10-20
Posted by Bob Kerr on March 04, 2004 at 20:45:05 from (64.12.97.12):
In Reply to: Age of McCormick-Deering 10-20 posted by Gary S. on March 03, 2004 at 10:36:07:
Most of the ones I have seen that have the exhaust that goes through the firewall (or front tank support)were built between 27 and 28. The earlier ones have 2 exhaust pipes that are just below the carb, one large dia and one small dia, and the 29 up manifold has the switchable baffles to run either gas or kero. If you get yours running it may not run good on gas when hot, just try kero in it as that is what those early manifolds were made to run. Mike is right about the serial number but I can add a bit to help you locate it, it is close to the lower water neck. I have seen a few though that were not stamped and they may have had the engine changed with a new on from the factory. I personally own 2 10-20 parts tractors that have had the engines switched from one to the other, luckily I bought those same two tractors at that auction, there were about 5 10-20s there! See if the serial number is on the boss, post it and one of us can give you the year and then check the date on the main frame casting, they should be pretty close. If all that fails, get a parts book and start looking up part numbers on everything. There were changes made all through the production even in mid year and the serial numbers for changes are listed. A couple things I can think of are the gear shift lever, in 29 was straight with no knob cast in and the older ones have a small knob, also the spark and throttle lever guide on the older ones have a small "arrow" cast in where you set the spark lever for starting, and the later ones don't have the arrow. Carbs another good place to look for numbers and were not too likley to get replaced since they are easy to work on. Mags are a bad place to get numbers since so many were exchanged over the years. You can really almost pinpoint the time the tractor was built down to the week, that is if it didn't have a bunch of parts replaced years ago. Some did, some didn't, depended on how hard they were used and how good of care was taken. Good luck!
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
