Re: Re: Re: Re: IH 674
Posted by Bernard le Mécano on March 05, 2004 at 20:23:33 from (207.134.20.92):
In Reply to: Re: Re: Re: IH 674 posted by clanger on March 05, 2004 at 16:22:30:
Hi Clanger, may be your transfert pump is worn. The return of the PTO circuit, go to the cooler then feed brake and lubricate upper shaft in the front gear-box ( 1234) The transfert pump give a back pressure to this circuit and lubricate pinion and bevel gear in rear housing, by a pipe below the tee where the sender is located. The overflow feed the main pump. If the transfert pump have not enough pressure, or flow, brake system don't work OK. If you have no much hill, you can remove the plug, as you say. It's a rubber plug, you have this one by the cover, on right side, in front of the rear axle. It's not a good idea, because the oil level is different in the 3 gear box. It's why you have to run the engine when you ckeck transmission oil level. On loader operation, when the transfert pump is worn, main pump may suck air because the rear housing gone empty. You may remove the plug in this case, but it's not like changing the pump. You may add 10 liters of oil when you remove the plug. Bernard le Mécano Québec Canada
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
