Carb parts mounting
Posted by Hendrik on March 08, 2004 at 23:18:37 from (194.53.253.50):
Bought an overhaul package for the Zenith carburetor of my Farmall Super A. The package contains 20+ parts and for most parts it is obvious where they should be mounted.
Included are two plastic foam washers (which fit on the throttle shaft and are approx. 1/16" thick). Where should these go?
Another question I have concerns the seal that goes on the throttle shaft. Normally (in gear boxes and hydraulic cylinders) the lip of the seal faces the "pressure" side. So in those cases one always mounts seals with the lip facing inward. Does that imply that the lip of the seal on the throttle shaft should face outward? (Pressure outside carb is greater than pressure inside carb.)
Your help will be greatly appreciated. Hendrik
Post A Followup
: Re: Carb parts mounting
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
