Re: Re: C123 engine overhaul max HP
Posted by Stan(VA). on March 09, 2004 at 05:41:20 from (208.59.156.207):
In Reply to: Re: C123 engine overhaul max HP posted by Red Rider on March 08, 2004 at 20:12:29:
Actually he can't if it's an original 140 block. They came from the factory as the equivalent of a C113 block with the 3" to 3 1/8" overbore kit already installed to make it a C123. Without doing custom machine work (and then finding custom parts) the best you can do is either get or save a set of firecrater pistons and use a new set of rings. The aftermarket TISCO pistons have a shorter piston and therefore a lower compression ratio. The good news is that you're not to far from your mark, look at 240 Utility HP numbers. Basically the same motor turning a little higher RPM (2000).
Stan(VA).
Post A Followup
: Re: Re: Re: C123 engine overhaul max HP
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
