Re: H problem
Posted by Bob on March 11, 2004 at 10:12:41 from (66.163.134.177):
In Reply to: H problem posted by Barry on March 11, 2004 at 08:38:39:
The problem could likely be a burned valve, but it would be a good idea to remove the valve cover, and check for proper movement of the valves on #1 cylinder. Do they seem to move the same amount as the other cylinders? Possibilites other than a burned or sticky valve are: valve set too tight, bent or damaged push rod, push rod out of place, broken rocker arm, bad cam lobe, blown head gasket, and probably a few more. Also, check for a carbon-tracked or cracked mag or distributor cap. If you narrow it down to a likely burned valve, you can verify this buy buying an adapter to screw into the spark plug hole that hooks to an air hose. You rotate the engine to a possition where both valves are closed, and apply air pressure. It will leak out the offending valve into the intake or exhaust manifold. If you do not want to buy the air-to-sparkplug hole adapter, you can make your own by breaking the porcelain out of an old spark plug, and welding or brazing in a pipe fitting that will connect to your air hose.
Home
| Forums
Today's Featured Article -
Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
