Re: farmall H rod + bearing clearence
Posted by riverbend on March 17, 2004 at 19:40:11 from (208.160.33.239):
In Reply to: farmall H rod + bearing clearence posted by Jonathan Mirgon on March 17, 2004 at 17:46:11:
You seem to be making pretty good progress on this motor. Connecting rod bolts should be torqued to 40 ft lbs. If you do not have the lock tabs, be sure to use something like blue locktite. The bearing clearance is 0.002 to 0.003", same as the main bearings (those bolts are 75 ft. lb.). Rod shells (mains too) go in clean and dry. Oil the bearings surfaces after you check the clearance with plastigage. With the rods and pistons installed, the crank may be hard to turn, but it should turn smoothly, without any tight spots. I had to fiddle around with the mains and rod caps to get the crank to turn smoothly. It helped to use two 0.005" feeler gauges on the same side of the joint. Be sure the crank turns smoothly on the mains before you bolt up the rods. The IH Service Manual for H from Binder Books very useful for this part of the assembly.
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
