Re: dishing wheels
Posted by Bob M on March 20, 2004 at 09:56:08 from (66.67.10.249):
In Reply to: dishing wheels posted by paul on March 20, 2004 at 09:24:28:
Paul - My son and I have did what you describe with loaded tires. So long as you keep the tire/wheel assembly vertical they can be handled by two guys without difficulty. We accomplished it without auxiliary threaded rod "handles" like you propose, though having them might have been helpful.
Tips:
- Attempt only on hard, level ground (slab or paved driveway).
- Jack and securely block both rear axles before starting.
- Allow plenty of work space on both sides and in back of the tractor.
- Have some plywood scraps of various thickness available to shim under the tires as needed.
- Wire brush/sand, then oil the outer ends of the axle shafts before starting.
- Most important: BE CAREFUL! Be prepared to jump out of the way should a tire start to go over.
Note it's easier - and much safer - to use a loader or backhoe and chain to handle the tires. If you have access to one, suggest you use it!
Good luck, and BE SAFE!
Post a Followup
: Re: Re: dishing wheels
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
