Re: Too young to know what kind of disc this is!
Posted by Ray in Pa. on March 22, 2004 at 22:08:23 from (205.138.20.161):
In Reply to: Too young to know what kind of disc this is! posted by Butch WI on March 22, 2004 at 14:01:17:
Butch, I use a 8 foot Mccormick NO.10A disc harrow behind my farmall 300 of which operates the same as the one you mentioned above. Mccormick made them in different width's and size. They made a Mccormick NO.10A and the Heavier model Mccormick NO.9 which had a roller on front frame. What I like about these disc is that you can power adjust them quickly to full digging angle with the tractor for going over fresh plowed area. Then gradually back off digging angle as you make passes to end up with smooth field. You can also wire on cement block for extra digging power if needed. I also use a large drag behind mine to really get a smooth finish. The only thing that one should keep an eye on, is that the bearing must be greased often since they are very exposed to dirt. I'm not 100 percent sure if the disc's that you talk about are the exact same ones, but maybe this will give you somewhere to start for help in identifying them.
Thanks, Ray in Pa.
Post a Followup
: Re: Re: Too young to know what kind of disc this is!
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
