Farmall Tractors Discussion Board
Super A Snowplow
Posted by Stan on October 21, 1999 at 06:31:03 from (12.67.148.118):
I have an snowplow that uses an A frame underneath the tractor that connects where the draw bar would bolt on as a hard point mount. As I understand it this is different than the blade made for the tractor. Raising and lowering the blade is done using only the drivers side hydraulic arm and a cable attached to very near the front on the blade. Hard point for the lift is forward of the position where the cultivators bolt on.
My question is:
Since the plow weighs at least a 150+ pounds do you think that will be too much for the one lift arm?
Post a Followup
: Re: Super A Snowplow
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
