Re: Re: Re: Water pump packing
Posted by John In Iowa on March 27, 2004 at 16:12:52 from (199.108.164.8):
In Reply to: Re: Re: Water pump packing posted by CNKS on March 27, 2004 at 11:25:26:
I work for a pipeline company and work on a lot of valves and pumps. Some pumps have mechanical seals and some have packing.
It sounds like the packing you are using is Teflon, which is very soft. The last packing that I got from our Dealer when redoing a Farmall 450 water pump was graphite, which is a littler harder and does not squeeze out as bad as Teflon. If these are spit rings, make sure you offset the cuts, I usually offset 45 degs. I have the best luck at work with a combination of Teflon and graphite. First ring in is graphite, then Teflon and the last ring graphite. With the graphite being the first and last in the stuffing box, it holds the Teflon in place and keeps it from be squeezed out. Hope this helps.
John In Iowa
Post a Followup
: Re: Re: Re: Re: Water pump packing
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
