Re: 300 Electrical Problem
Posted by Mark Witt on March 29, 2004 at 10:46:38 from (65.216.75.240):
In Reply to: 300 Electrical Problem posted by Dave K on March 27, 2004 at 12:04:57:
Dave: By "starter switch", I assume you mean the solenoid with the + cable from the battery going into one side and the cable to the starter coming out the other side, and each cable attached with a terminal, stud, and nut. If that's the case, the most common way I've seen these bypassed is with a pair of pliers. Or you can use jumper cables instead. - Turn off the ignition switch. - Disconnect the coil wire. - Put the transmission in neutral. - Set the brakes. - Leave the spark plugs in to give the battery and starter motor a realistic challenge. - Open the pliers until the handles are far enough apart to span both battery cable terminals on the solenoid. - (Did I mention turning off the ignition switch, disconnecting the coil wire, taking the tractor out of gear, and setting the brakes?) - Press the plier handles to the terminals so current passes directly from the + battery cable through the pliers to the starter cable. Now the switch is bypassed. No activity (or slow starter motor)? Check the battery, starter, and cables. If the starter works fine, put the pliers away and actuate the starter switch (with the tractor still disabled). If the starter doesn't move and you don't hear a click from the solenoid, then either the solenoid isn't working or it's not getting a signal. Pull one of the small wires off the solenoid (or maybe there's only one, I don't remember). With the starter switch not actuated, the wire should have 0 volts. With the starter switch actuated, the wire should have (in your case) 8 volts. If not, you're not getting the right signal from the starter switch. If the signal is good AND it's attached to the correct termial on the solenoid, and the solenod's not clicking, then the solenoid is bad. I doubt you have a bad solenoid. In my experience the solenoid either works great or not at all, so the slow cranking you described would not apply here. Maybe other contributors have had diffeent experiences, though. Another thing that can cause problems with starters is that they can sometimes bind if you install them just a hair off from where they "want" to be. Again, I don't think this is your problem, but if you've had the starter off you may want to loosen it just a little and re-tighten it. You can measure 8 volts somewhere, but you still may not have meaningful current available. If you have a problem like a rusty, dirty, or loose cable connection (on the ground side or the non-ground side), it can pass a few milliamps or even microamps -- enough to make your voltmeter happy. It won't do a thing for your current-hungry starter, though. Make sure BOTH ends of all your cables (battery +, battery -, and starter) are clean and tight. Good luck. Let us know how it turns out. Mark W.
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
