Re: 240 Utility hydraulic problems
Posted by Joe Evans on March 30, 2004 at 06:37:59 from (209.41.233.202):
In Reply to: 240 Utility hydraulic problems posted by Ed in Bland on March 30, 2004 at 04:22:53:
Ed: Get yourself a manual if you don't have one. The I+T manual that I have for the 240's larger kin, the 460, does a pretty thorough job in explaining things. There are some slight differences in the hydraulic systems of the Utility vs the Farmall. The manual will explain those. Having said that, it sounds like the feedback linkage from the fast hitch rock shaft to the fast hitch spool valve is not adjusted properly, have parts missing, or just may be unhooked. I'm assuming the 240 has a Tel-A-Depth feedback control (the linkage just mentioned is part of this), there might be a problem with the little differential gearbox that is inside the rear cover cap of the fast-hitch spool valve. If the gears are stripped or the gear axle pins are wacky, the system will fight itself. I'm not familiar with a 240, but it probably isn't too different from the 460. Again, get a manual. PS-One very important item to check: there is an orifice plug and screen located in the control/pressure regulator block. If this is plugged, the regulator valve can't get a signal to unload the hydraulic system when flow is not diverted to other tasks such as raising or lowering the hitch. A tell-tale sign of this is an RPM increase when actuating a cylnder, then an RPM drop-off when cylinder movement stops.
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
