Re: Carb adjustment running to rich?
Posted by Wayne Swenson on March 30, 2004 at 07:53:22 from (66.228.234.4):
In Reply to: Carb adjustment running to rich? posted by Mark in Mi on March 30, 2004 at 05:05:49:
With the engine warm & running at wide open throttle (WOT), turn high speed mixture screw in until the engine begins to starve for fuel. Then turn the screw out until it begins to blubber. Now find the "sweet spot" in between the two settings. If you are working the engine (plowing, etc.), then the high speed screw needs to be turned out 1 turn or more to be sure the engine isn't running lean.
The same proceedure can be followed for idle mixture with the addition of the ldle stop screw to set the low speed RPM. On the "H" carb, the idle mixture screw is an air adjusting screw so turning in will richen the mixture and out will lean the mixture.
Aren't carbs fun!!
Post a Followup
: Re: Re: Carb adjustment running to rich?
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
