Re: Re: Re: Re: Re: Re: Re: Re: Re: 414B ENGINE
Posted by jdemaris on April 07, 2004 at 18:55:17 from (209.23.30.173):
In Reply to: Re: Re: Re: Re: Re: Re: Re: Re: 414B ENGINE posted by Greg on April 07, 2004 at 07:59:52:
I assume you're going to use the Delco 10 or 12 si, it's the most common for this purpose - although I've been using Hitachis lately, taken of older Subarus. They have the same hookup, but are much more compact. Anyway, the alternator has the main battery post, and then a harness plug connects to the top of it and it has two terminals, #1 and #2. #1 goes to switched current, i.e. hook it to the IGN terminal of the ignition switch with at least 16 gauge wire, as long as you have a diesel and not a gas engine. If you want to install a charge indicator light, put it in line between the #1 terminal and the IGN on the ignition switch. #2 terminal on the alternator is for "voltage sensing." It tells the internal regulator what voltage is at the battery. On a machine where there is a long run of wire, this wire would go to the postive post on the battery because the voltage there can be slightly different than at the alternator. For hook up on your tractor, you can just connect it to the large post on the alternator - so just put a jumper wire from #2 to the large BAT post, maybe a 2" or 3" piece of 16 gauge wire. Now, that large BAT post on the alternator goes to the positive post of your battery. It needs to be heavy wire, at least 10 gauge, but 8 is more adequate. Your ammeter goes in line with this wire, i.e. somewhere between the alternator and the positive battery post. A few notes: You don't have to actually hook this big wire on the battery post if there are better places that are closer. On some tractors, it can be put on the starter relay or switch post if you have one. What ever you hook it to, it must eventually hook to the positive battery post and must be at least as heavy as the 8 or 10 gauge wire. Some tractors, cars, etc. don't use direct reading ammeters anymore. The reason being it entails using too much wire. On your tractor it probably won't make a big difference. On a car or truck, the big charge wire would have to run a long, long way. So, in those cases either volt meters are used - which don't need heavy wire, or "shunt-wired" ammeters are used. They give a representative reading. In general, a shunt-wired ammeter that shows 30 amperes of charge might only have 3 amps flowing though it, so it only allows a fraction of the available current to flow through it, and therefore uses a small wire, but lies to you and pretends it's doing more. In the end, you are still seeing an acurate reading, it's just kind of lying to you for your own good. I probably told you more than you want to hear.
Home
| Forums
Today's Featured Article -
Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
